holy cow i haven't posted in ha section so long i feel like a outcast.
heres a pic of mine. pretty much same as brads. used the caspers fan relay and is controlled by 87 ECM. fans are the dual ramchargers that gbody parts sells and after you shave the plastic side clips they are perfect fit inside the autozone $95 dollar fbody radiator that drops right in perfect fit, held down by the 86/87 (and other model v8 gbodys) radiator hold down plate.
Never any problems (knock on wood
) with the fans full blast dragging down the amps, but i've done the 140 amp conversion also (na 3.8 alt bracket w/lt1 alternator).
temp stays at 160-165 no problem. think i seen it go up to 175 a couple times on 95 degree plus days, but isn't a issue with me.
i also added a combo oil/tranny cooler and doesn't seem to affect the performance of the fbod radiator and ramchargers fans either.
for no more money than was spent, (did all work myself), you just can't beat this combo imo.
