Just wondering what style breathers guys are using with the electric pump set up? If anybody has any pics of there set up that would be great too. I did some searching on the board and have read alot of positve things about this set up.
thanks joe
Generally you don't want breathers with a vacuum setup because you will never actually pull vacuum, you will just circulate air which IMO is not worth spending money on when your PCV valve leaks boost in the crackcase (without a check valve) and out the breathers anyway. Need to add a check valve before the pcv so no boost leaks past and also need to plug off the dipstick tube so there are no leaks. The only leak should be the output of the pump. Enough of my evac rants. Search a bit and you'll find a thread I started about my setup, that always seems to be "in the works". heh.
