Hi. I searched but couldn't find a diagram of where the vacuum hoses go between the solenoid and EGR valve. Coming off the top solenoid tap/barb is one hose that tees off into two hoses and forms a y-shape(One hose has a check valve on it and there is a second hose coming off a vacuum tee which isn't connected to anything).
The hose coming off the bottom tap from the solenoid is a short hose with nothing connected to the end. So essentially, there are two hoses coming from one solenoid tap and one hose coming from the other solenoid tap for a total of three hoses that need to connect to something. Which goes to the vacuum block and which goes to the EGR valve? How do the two hoses coming off one of the solenoid taps connect into another hose? Thanks!
