I am getting a code (42 I think) for EGR Solenoid. I am now having a really bad idle when the car is cold and not much better when hot. I tried checking the EGR Solenoid with the Mighty Vac and it holds no vacuum with car on or off, is this normal? I did a search of the archives and found that it should be normally closed but has a bleed to it, how much should it bleed if any? I am at wits end trying to get my car running descent without just dumping money into it, so any help would be appreciated. Thanks
PS, I checked the entire ignition system and everything is fine, so it isn't ignition related, and the EGR code is the only one I have ever gotten on my car.
