reading through the past posts about this thing i'm a little confused... it would seem as though there is no way to have a rev limiter, two-step, or shift light triggered from this system? can that be??? surely i must have misread...
also, where can i find specs on what signals the system needs and how it is actually wired... for example, do the crank pulses need to come at exactly TDC for each cylinder? and is the once-every-time-through-the-firing-order cam pulse required to be in a certain range (like at least 20 degrees before a crank pulse or something)... just trying to figure out how to set up my sensors to get the signals i need... as far as the overall system layout, do the crank/cam signals go to the FAST box first just like a normal SEFI layout? and then it sends the spark trigger signal to the eDist? i would think the eDist needs to know the crank/cam info itself too... basically, as you can tell, i'm starved for any and all info on this... i've read every edist post on here but i'm still lacking!
thanks,
Jeff
thanks,
Jeff
