CrashMaster
- Jun 23, 2007
I have tried to search this site, but I come up empty.
OK, my ECM died and left me stranded and had to get towed home. This was after I had put a new ground wire directly from the negative battery pole to the body. I screwed it into the body with another ground wire from the wiring harness. When I turned the car on, the fan came on and the scanmaster wasn't receiving any information from the ECM. I thought that the connections on the scanmaster came loose and that the fan solenoid had gone bad. No big deal, I just wanted to drive it around which didn't last long.
When I put the spare ECM in, everything ran good for a day, the fan only came on when tripped by the ECM and the scanmaster received data from the ECM. The next day, when I turned the key, the fan came on and the scanmaster wasn't receiving any data from the ECM.
Now, I have removed the ground wire that I installed, but I don't want to install another ECM until I know what is wrong. The car is an 84 TType converted to the 86/87 engine. The ECM is dry, the car sits in my garage, I have a new Caspers wiring harness installed. I am still using the same fuse box though.
I really need some help here as I am only a shade tree mechanic, not a pro. I'm a geek. Please help.
