Just got my GN (had from new)hooked up to my lap top and want to know the optimal readings of my sensors (blms,o2,maf,iac,int) at idle, mid range, and wot. The mods I have on the car are green strip injectors,adj fuel pressure regulator,hot wired fuel pump,adj wastegate, casper dial chip(burned for the green stripes),and next larger cam (wiped lobe on stock cam). 62,00 miles. The only problem I am having is knock before the 1-2 shift.
If someone can hook me up to a web page or give me some readings will be a big help.
Steve
Steve
