J JOELO'S T-TYPE Member Joined May 11, 2006 May 9, 2009 #1 What are the advantages and the parts needed for an ecm conversion?? (HA to I/C) Thanks a lot!
T TurboRegal84 Moderator Staff member Joined May 24, 2001 May 9, 2009 #2 The biggest advantage with the 86/87 ECM is the ability to use Scanmaster.
T turbonut85 Rarely used member Joined Apr 11, 2008 May 9, 2009 #3 TurboRegal84 said: The biggest advantage with the 86/87 ECM is the ability to use Scanmaster. Click to expand... X2. Parts needed are: 87 ECM...obviously:redface: 87 MAF Sensor TT chip burned for your setup....HIGHLY reccommended!! IAT sensor setup...if desired. (TT can disable this if you want.) HTH ---Keith
J JOELO'S T-TYPE Member Joined May 11, 2006 May 9, 2009 #4 Thanks a lot, I was set on converting to 86/87 setup but i think i'll keep my turbo where it is........ with some minor mods
