ECM conversion question
The biggest advantage with the 86/87 ECM is the ability to use Scanmaster.
X2. Parts needed are:
87 ECM...obviously:redface:
87 MAF Sensor
TT chip burned for your setup....HIGHLY reccommended!!:D
IAT sensor setup...if desired. (TT can disable this if you want.)
HTH ---Keith
Thanks a lot, I was set on converting to 86/87 setup but i think i'll keep my turbo where it is........ with some minor mods :)
