That might be an issue for me seeing as how on my initial start up i didnt have the IAT installed anywhere at that time, wheres the best location for the IAT?...Im not as swift with this system as some of you but i will make it work for me eventually..i wanna say thanks again for helping me with the questions i have---there will be moreYes. The car that was used for the included calibration has the IAT in the plenum. Like your car it too has a large front mount.
RemoveBeforeFlight
Ok, getting somewhere now, relocated the IAT to the intake, ran a wire from F15 to the B terminal on the map sensor...Runs pretty good now and no codes. Im still not real sure about the VE learn, does it allow the ECM to self learn based on driving habits?
My fans not coming on...Is there a setting for this
Looks like the O/S (Windows) has things locked up, IOW, the security level is too high not allowing programs to create files.
Do this to both the WUD and Tuner Pro: right click on the Desktop shortcut, then select the Properties dialog. In that dialog, Windows version dependent, may be a line that states close to "Run Program as Administrator." If so click that line to check mark the box next to it. Click OK and do the same for the other Shortcut (WUD or TP).
If no line to run as admin, click the Compatibility tab. Look at the entries there for one that states to Run as an Administrator. When found click to check mark it.
Now try Tuner Pro again to see that it can create the log file. Same for the WUD, can start a VE Learn then just stop it (no need to connect to EBL SFI-6 ECM). See if the WUD can now create the new BIN file from the VE Learn.
RemoveBeforeFlight
I set things to run as Admin but im still getting this message when i try to change the coolant fan on/off temps..However im able to do VE learns now and flash them into the ECM succesfully which is really nice and is working out great but i dont like seeing my temps too high.View attachment 247703 Im not able to change my fan settings, what am i doing wrong?
Or build a file thats emailed and then flashed to my ECM?
