E85, iron heads and 30 PSI, What / which spark plugs to use ??
What brand spark plugs to use?
What heat range to use?
My car is a 99.99999% street car BUT I will be going to the track real soon and I will push the car HARD.
Right now i am using AC Delco R43TS or CR43TS gaped at .30
Talk to me guys.
I would use Autolite AR133 or AR124 with a gap at 0.028"
These are race plugs and have heavy electrodes, and are NOT projected tip which will be much less prone to the effects of high heat, especially at 30 psi.
The AC Delco junk plugs have proven to be very unsatisfactory for us on street cars, and would never trust them in a race application.
Sorry, my typing sucks, should be AR133 or AR134?
The AR133 is the colder plug which I use for higher boost.
Hey TurboPower.. Grab a set of NGK's UR6's & gap them between .025-.030
Gabby.
Ar133, the colder the better
Gabby.
UR5's would be better at that boost or use a YR5 for a non projected tip plug. .025-.030 gap with stock ignition.
To follow up the op's question, what about when using a tr6? Plug, gap and heat range? Thanks
I used TR6's on my GN1's & ran 9.3's with them with no problem lol
Autolite had a 132 plug also but I think they discontinued them. Same thing with the AR3932, coldest plug but not available anymore.
