G gn-t-type 16 PSI JUST LIKE YOU Joined May 28, 2001 Sep 8, 2005 #1 on a good safe tune how high will it go thanks rob
G gn-t-type 16 PSI JUST LIKE YOU Joined May 28, 2001 Sep 8, 2005 #3 gndemon I WILL CALL GEAN HE WILL TAKE CARE OF YOU :tongue:
T TurboTR sprayhead Joined May 25, 2001 Sep 9, 2005 #4 Yeah what he said As the hp and flow climbs out the roof, egt tends to get a bit hotter too So, it depends on what you are doing really. TurboTR
Scott Atk Senior Member Joined May 25, 2001 Sep 12, 2005 #6 It depends on where your sensor is located. If you are sensing at the inlet to the turbo somewhere near the stock o2 sensor then 1550 would be a safe tune. If you want to go to the edge then look for 1650 - 1700.
