E-Boost Boost Controller
TurboNova
E-Boost Electronic Boost Controller
$350
here is what their website says.
The e-Boost electronic boost management system is the culmination of many years of research, development and innovation, with countless hours spent testing on the dyno, the race track and the drag strip. The e-Boost is the worlds first re-programmable boost controller utilising FLASH memory technology, making it compatible with future software upgrades, meaning your e-Boost will never be out-dated. The e-Boost is more than just the best performing electronic boost controller, it is a complete boost management system, making Turbosmart a world leader in boost control systems. This revolutionary product is loaded with features, squeezed into a package small enough to fit in the palm of your hand:
The latest in Hi-tech electronics, featuring a 16 bit RISC based FLASH memory CPU – faster and smoother boost response
Utilises the latest in surface mount technology – lighter, smaller and ultra compact
Electronics are housed in an anodised billet aluminium alloy housing – offering durability and reliability in harsh race conditions
Programmable gate pressure function to totally eliminate wastegate creep - you tell the wastegate when to open
Three internally or externally activated and individually programmable boost set points
Drag racers - improve your launch, run a different boost in each gear
High accuracy boost and vacuum display, readout accurate to within +/- 0.5% of full scale, boost gauge no longer required – great value
Readout can be tailored to suit your needs – display can be configured in KPA, Bar or PSI
Easy to read seven segment display with programmable bar graph and glow in the dark buttons
Programmable auxiliary output – e.g. water spray control, water/methanol injection, boost light
Programmable audible warning alarm – excellent for over-boost warning or full boost confirmation
Peak hold/Max Boost recall function
Revolutionary gauge type construction allows many practical mounting solutions – 66mm in diameter 55mm long. Suitable for Panel mounting, or in any 2 5/8 inch gauge pod or pillar mounting system.
Why did you get rid of that unit? Seems pretty neat.
What do you use now for boost control? I'm in the market for something.
Roger
Roger
I am switching to the new MSD unit and will use it with CO2
