So I took my car to the dyno for its first time. And it had 270hp and 390 ft-lbs. The problem with these numbers is that the car was running so rich that it didn't even register on the a/f chart so it was richer then 10.1. I kind of knew i was running rich because when I mash the gas the car wil just bog and not go from a stop, it does a little better from a roll. So I need some tunning pretty bad.
te-45 turbo
206 cam
50lb injectors
p&p stock heads
43psi fuel pressure regulator
turbo tweak chip
running 20lbs of boost
Thats all thats done to the motor. So what do you guys think i need to do smaller injectors
te-45 turbo
206 cam
50lb injectors
p&p stock heads
turbo tweak chip
