I've got a few errands to run today and will be doing some playing around w/ the system. I've currently got 93 octane in and will be doing some 14-15psi stuff; nothing too, too heavy. I'm still running the stock, top-mount IC until we get the A2W intercooler core done (needs piping and water fittings welded on). My plan is to start trimming fuel out and get the alcohol injection curve setup. I am currently running one M15 nozzle in the throttle body inlet adaptor. Since I have an FC, my air intake temp sensor is in the same location so I won't be able to see on-the-fly charge temp differences, but that's changing later this afternoon or early evening when I remove the LIM and put the sensor in there. I'm curious anyways to see what the charge temp differences are given the fact that the turbine housing is parked alongside the manifold and may cause heatsoaking (even though I've got a turbine blanket and a pair of intake manifolds that are ceramic coated.)
I'll get back with you guys to let ya know how things work; hopefully have some datalogs too. For those of you that don't know, I'm one of the (only) two rotary owners who's using Razor's kit. Me and Howard Coleman, author of the infamous "CHART", are experimenting w/ straight methanol injection on the RE w/ Razor's hardware and electronics to see if it's a viable solution to our overall reliability problems. Here's pictures of my installation:
http://bdc.cyberosity.com/v/ProjectCars/BDC/AlkyControl/
Ya know Razor, I think we might be larger than 1gal fuel cell. May have to step up to a 3gal...we shall see. I'll let you know what I wind up with today.
B
B
