Originally posted by TurboSy
Ok Bruce after reading a bit I have a question. Currently I'm running an afr of 12.0-1 without WI, I guess I'm fuel dumping to off set detonation. Is the idea to replace fuel with water as a means to control detonation? Is it theoretically possible to run an afr of 14.7-1 at wot if you could inject enough water?
Your asking good guestions!.
Trouble is there isn't short answers, but in summary.
Adding fuel is to cool the chamber.
You can do the same thing with water.
When introducing water you can do it by atomization, or vaporization. That's why people have better results with differing brews of alky/water.
In theory?, Yes.
But, in actual application there is more to it then that. Reading the Harris notes will explain the chemistry end of things better.
A couple freebies:
On a pulling tractor they use as much as a gal of water in 20 secs.
When test firing the WI system on the tractor, it makes a cloud of water vapor that takes 30secs or so to disapate. It's seriously atomized.
The discharge tube off of the turbo turns the paint to charcoal, but starting at the first WI port the paint is perfect. And I do mean charcoal, and I do mean perfect.
