What do you do? Wait for them to crawl under the car and then drop it to the ground?
That will work ! Nope with the smart phone App you can completely control your suspension without the E3 in-car controller (Now you can Hide that or simply remove it all together) Then with the car is dropped in the "Parked" setting or slammed to the ground as some say, the car is so low that you can't turn the front wheels so unless someone comes with a flatbed and tows it away the car isn't going anywhere fast that's for sure.
Here is what it looks like on your phone and some info on the App.
The e3 system takes another leap forward with the new Ridetech iPhone and Android application that allows you to control your ride height straight from your phone. Using the same basic setup of our previous remote system, the e3 smartphone remote app is simple to install, easy to use, and convenient for those who carry their phones to every situation.
General Features:
• Available on BOTH iPhone and Android devices
• Utilitzes Bluetooth technology for superior security and connectivity
• Compatible with any e3 RidePro system
• Adjustable ride height from several yards away
• Displays live information on air tank and airspring pressures
• Includes 3 ride height presets plus controls for each vehicle corner
• Landscape mode imitates e3 controller
How it works:
The application is available on any iPhone or Android smartphone device. Using your phone's bluetooth connection, the application will send remote commands to your e3 system through an external antenna. The antenna relays important information back to the phone such as air and tank pressure. Menu items can also be changed via your smartphone, just like the original e3 display. The application and antenna will work with any existing e3 system.
What is included: wiring, 2 remote key fobs, the bluetooth antenna box, and the application software.
NOTE: If you already own a e3 remote kit, click here to purchase the updated bluetooth antenna
Available on:
