I thought you were supposed to use distilled water so the minerals won't clog up the radiator. Local radiator shop told me that coolant breaks down the minerals so tap water is fine. They checked my radiator and said it flowed good, no problems. Just a couple small leaks which they fixed. I always used tap water and coolant. And RMI-25. I went ahead and bought the 50/50 mix anyway, for my new radiator, as I was too lazy to mix it myself. So (a) Is tap water ok and (b) do you think the 50/50 mix uses distilled water? It doesn't say on the Prestone label.
