I have a T61 turbo, BGC 3" DP, 42.5# injectors, Razor Alky, Translator Pro, mild ported heads. It sucks when you buy a car like that, going off of what the previous owner told you. I just bought a Precision 6765 billit wheel turbo. The car puffs smoke and theres some play in the shaft on the turbo. You think the F350 intercooler will work? Im also concerned about cooling of the car too. It does run hot. I have a single fan behind a stock radiator, and I do have a 160 therm. Cruising around it will reach around 200-205. I live in Tucson, so it is hot out already, once I start playing with it it will creep to 110 but no higher.
