After showing wear on both gears (1 season of street driving and some track run) I raised the ? about gear wear. This was few years back. I have a Comp billet cam and a factory cam sensor. The gear on the cam is a factory 350 buick gear. Did not get a clear answer. After going through 2 sets of gears I decided to look into this farther. On a factory GN cam there is a hole drilled @ an angle from the front cam bearing journal out to the end gear. It looks like enough oil will weep out onto the gear to keep them from eating each other up as I have not seen factory stuff show wear. With a billet cam that oiling is eliminated. I drilled and tapped a 1/8 in. NPT hole in the front cover just above the cam sensor gear. I had to drill the brass fitting out so the 1/8 in. copper tubing will slide on through the fitting and you can aim it so it sprays directly on the cam sensor gear. (there is not enough room for a fitting inside the cover.) The cam sensor gear turns clockwise looking down on it and the cam gear turns clockwise looking @ it from the front.The oil on the cam sensor gear is carried around to lube when they mesh. 2 years now and 0 wear. I could post a pic if needed. BTW I pick up my oil supply by Teeing into the brass factory fitting on the front of block.
