digital to analog dash??
Mr. Spina would know this. I think it would be a huge pain. The dash harnesses between the two are very different.
first get an analog dash cluster and an analog dash harness (if you have security and want to keep it you will need an analog dash harness with security)
simplified description of whats involved ...pull digital gauges , pull entire dash with harness, swap harness , replace dash , install analog gauges remove hobbs and install a map sensor
only need a few tools like a thin screwdriver to separate plug connectors , some sockets or nut drivers 1/4, 7mm, 8mm , 10mm and , 15mm (to lower steering column)
sounds simpler than it is . with experience its a couple hours , first time it might take a weekend, for some it may be more than they can handle.
Are the speedometer cables the same for both cars?
