Denso lead proof 02 sensor
FLYNRYAN87
How are some of your results? I have ran thruogh 20 gallons off 100 octane and about 400 miles of driving and street racing and still going strong.
I take it your running 100 octane leaded?
at that level I'd just get unleaded
but good to hear the results so far
I installed mine and ran 5 gals of 110 through it at he track. Been driving with 93 in it for the last 2 weeks. So far switching just as fast. GM o2 would be on its way out by now. Cheap too!
Mitch
denso oxygen sensor
I have put about 100 miles on mine with 114 leaded sonoco race fuel. Still as active as the day i put it in. For $26 i think that what it was, it is a very good deal. i think everyone should have one even if you run pump gas. One less thing to worry about.........Bob:)
100 Low Lead Isn't....
FLYNRYAN87,
Thanks for your report about this sensor's performance.
Just a note about the so called 100 "low lead" AVGAS. It has a LOT of lead in it. My neighbor, a career specialist in fuels, tells me there is way more lead in that 100 Low Lead than they EVER put in automobile gasoline. If that sensor lasts with the AVGAS, then, its a breakthrough. I'll be watchin for your updates. :)
Is the one everyone using the one wire or the heated ones?
Id rather use the single wire ones if possible..
Thanks,Brian
Nick, shoot me a price for the single wire shipped to 64114. I like the thought of one less thing to worry about:) Do you take paypal?
I talked with the Denso rep and he stated all 02 sensors are made the same single and multi wire. There is no advantage in the use of multi wire in turbo cars. I switched back to single wire.
