On the truck less than 5000 miles, worked beautifully when removed. Specs from Delphi:
Static Flow Rate @ 43.5 PSI (300KPa) = 75.0 lb/hr / 9.5 gm/sec / 788 cc/min
Static Flow Rate @ 58.0 PSI (400KPa) = 86.6 lb/hr / 11.0 gm/sec / 909 cc/min
Dynamic Flow Rate @ 43.5 PSI = 1.75 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 2 Ohms / Low Impedance / Low-Z (Peak-hold ECM drivers or impedance converter required)
Cone Spray Angle - 22.5 degrees - single spray cone. Approximate cone angle for 90% of spray volume
PTR Injection sells these new for $450 + shipping for a set of 6.
PTR Injection - fuel injection,engine management systems
Looking for a quick sale, so I will go with $300 shipped. First one with the cash gets the injectors. Will accept cash, check, money order, or paypal (buyer pays fees).
- Matt
- Matt
