Has anyone had this problem? I have a stock 1985 GN and use a tec 1 for data display. I have loss assess to reading my data. The car runs fine and the check engine light comes on when I key it up and goes off when started. I am able to short out the test connector and it will flash a code 12 with no other codes. I have tried the tec 1 on other cars and it works fine. I have another ecm and chip that I could try in the car, but without knowing the problem I do not want to install it for fear of damageing the computer. Is it possible that the computer or chip has failed? If so would this still allow me to read a flashing code 12 from the connector? I am at a lost on this one. I have checked all my grounds & power to the ecm and they seem to be OK. If you have any ideas they would be greatly appeciated.
Thanks, John gntype@aol.com
