Both my motors have been cryogenically frozen.
Here goes:
I would have the motor dis-assembled before it is treated. When the parts come out of the vat, they are ditry and need to be cleaned. For the price, you can't go wrong. The treatment companies charge by the pound or basket load.
On the first motor, I have all the machine work done before treating. When the block came back, the mains were out and needed to be re-lined honed. So this tells me that cryo does something. I had the block, rod, pistons, rings, and the crank treated. The crank was also nitrided. I installed Fed Mog Super-Duty Alloy Main Bearing (big mistake) and they got totally chewed up at BG. I spun #4 main on this motor while at the track. The motor had no knock and I continued racing it. Usually when you spin #4, the block cracks. My block did not crack. I had to throw this block away because I could not get a reference to line hone the mains. #1 and #4 mains are used for your reference points. The crank was fine, all it needs is a polishing.
The motor I am almost finished building now also was cryo treated. I put the new Eagle crank, block(unmachined), rings, bearings into the liquid nitrogen.
On my Ford Diesel Pickup truck, my front rotors were cryo treated also. Ford trucks warp and crack front rotors easily. So far my are still good.
Anyone that I talked to about cryo treatment never said anything negative about. All they said was "why do you need that"
The treatment company puts the parts into liquid nitrogen which is approximately -300*F. The parts stay in there overnight and they are slowly brought back to ambient temp. Usually the parts are dipped twice a week, Monday/Thursday.
Another good part of cryo, if the part has a crack in it, it will fail while being treated. Example, If the block is cracked and it not picked up by magnaflux, it will crack while being frozen thus saving your time building the motor.
Hope this helps
Billy T.
gnxtc2@aol.com
