Daniel Jost
Squirtin six
- Oct 11, 2003
Ok guys bear with me here,
I bought my car 8 years ago from an owner who used to show the car, it had the Cruise control removed. When I say removed I mean that all the wiring and the cruise control assembly was removed under the hood. I have the cruise control stuff that the old owner gave to me, I just dont have a clue where the wiring is? I have removed the stock harness and when I pulled it apart I found several cut wires that went to nothing, were these it? My brother has a 88' Monte SS and his car has the CC harness coming through the firewall and it plugs in under the dash. I dont really care about where the stock wires are as much as wiring the new one? I dont have the dealer service manual with me so I cant see the schematics. I need to find the plug coming from the CC lever on the column and know what the pins do, and run it to the cruise module under the hood through my new custom engine harness. From what I understand the cruise does not use anything from the ECM, just the speed sensor and brake inputs?
Thank You, Dan
Thank You, Dan
