GangsterMD
Turbo'd since '95
- Dec 29, 2007
Hi guys, I've read a lot of posts about the above. Do any vendors actually sell a nice clean system?
D
D
Here is an evac system we developed for the turbo Buick V-6. :biggrin:
It is made to work with a Champion AC delete bracket and is belt driven off the water pump.
The accumulator is hidden under the inner fender, and the pump has a regulator on the inlet fitting.
Has worked flawlessly for 3 years and pulls 10-15" vac.
Yes, I log crankcase vac, and I have it set at 10-12" through a 1/4 mile pass.
The parts for this system runs about $800+.
The only issue is if it does NOT work, I loose about a .1 sec and 1-2 MPH, and blow oil all over.
It reads 10-12" through the entire run, and can regulate it higher if wanted.
Unlike the electric pump it replaced, this has never failed. :biggrin:
I've got a bit of oil tracking down the dipstick when I've been racing. I'd like to stop that obviously. But I'm not prepared to get rid of my a/c - so I think Nick's system is out for me. I'd like to find a nice little electric vacuum pump to run through a separator... Has anyone used anything like this?
