J jdsgnx Well-Known Member Joined Mar 2, 2002 Oct 4, 2012 #2 use a bussiness card or match book cover JD
M mrtiptop Member Joined Apr 21, 2003 Oct 4, 2012 #3 jdsgnx said: use a bussiness card or match book cover JD Click to expand... Thank U !
G GNVenom Well-Known Member Joined Jan 6, 2002 Oct 4, 2012 #4 http://www.installationinstructions.com/FYI/cranksensortech.pdf for some tech info.
J jdsgnx Well-Known Member Joined Mar 2, 2002 Oct 5, 2012 #5 mrtiptop said: Thank U ! Click to expand... Welcome!!!
M mrtiptop Member Joined Apr 21, 2003 Oct 14, 2012 #6 Rockauto.com STANDARD MOTOR PRODUCTS Part # PC8 {#1103691, 12537109, 213158, 213292, 25526123, 25535480} CRANKSHAFT SENSOR [Wholesaler Closeout -- 30 Day Warranty] $27.79
P Pwt Member Joined Apr 21, 2015 May 11, 2015 #8 mrtiptop said: How do you set the Gap on a Crank Sensor ? Click to expand... When installing the mounting bracket watch out for the 3 wires to the crank sensor.I made the mistake of crushing them in half when I changed mine out.
