I had a CPT 66 BB with a stock converter for awhile, ran awesome with alky.
I have recently gone to a GTK-850 BB from Turbonetics and can't wait to see how this thing is on the street.
I would think about what your goals are with your car and then call Jack Cotton, he will set you straight.
Bryan
Was it a BB?My 66 w/.85 housing spooled sloooow with a 3200 lock up converter in it. Others have said they had no problem but mine was a pig.
TA-60 50lb injectors Turbo Tweak Chip.
I just installed a ball bearing 67-Ptrim w/ .63 housing on a car with a 3200 stall. He has 60lb Inj, 340 pump hot wired, Alky, and a front mount, mildly ported heads, & steel mains. The car launches hard but when that turbo lights it's all over the road at 20psi. Stock suspension stock wheels and tires, stock shocks, no X brace nothing all stock. Should run low 11's High 10's if it hooks at a track.
PT 61 does well.....I know you liked it Brent
Bryan,
How did the 66 spool with the stock converter? And what other mods did you have done on the motor? Sig?
My 66 is a ball bearing unit. Spools like a stocker with my new converter. The 61 spooled awsome with a pro-torque 3200 stall. They are both ball bearing units. The pro-torque was way laggy with the 66.
