coolant tank
dadmomcat
Has any one used the radiator coolant tank as a holding tank for a gravity feed into the SMC tank ?? I have mounted steve's tank below the coolant tank and would like to use the coolant tank as a point to refill the system. What type of hose should i be using from the coolant tank to the bottle ?? Any ideas would be helpful.
I havent done it but you should proabably use some sort of polyvinyl hose to avoid any sort of reaction from the alcohol.
