So even after reading a lot of threads on this topic, I'm still confused on what my prob is. I have a pan in my garage to catch the 2 drops of oil that come out after every drive. 2 days ago my wife calls me at work and says the pan is half full of water. Never seen that before - it had rained that day...maybe just run off. Today, another pile of water in the pan (a pint or so). It's coolant (I use RMI and distilled water).
Okay, so it's not a leak per se. Ran the car today - no leak at work, no leak back at home (but I came home early with no traffic, i.e. car wasn't idling a lot or running hot). Checked all hoses - dry. Overflow was empty so I topped it off. Ran the car again to get it nice an warm and let it sit in the driveway running for a while until the temp got up to 185. Tried heater and air conditioner. No leak. Turned car off and about a cup of coolant spilled onto the ground - came out the holes in the cross member. Doesn't look like there are any leaks from overflow or radiator or hoses that I can see. Definitely some wetness low on the block passenger side. In fact there were a few drops/spray on the intercooler bracket (maybe flung around from fan or belt?). Definitely not a drip drip leak. It pisses then stops.
So as of now...seems to only happen when hot. Drove 15 miles this evening to pick my son up from school and not a drop - (radiator and overflow still full).
I have a 160 deg thermostat and engine always runs very cool when moving. When stopped and idling (traffic, lights) and the car is warm/hot, temp creeps up to 180-85. When it was 110 this summer and I was stuck in DC traffic, I would get up to 200-205. As soon as the car starts moving, temp drops back down.
I'm sure it's obvious and I'm just stupid. Tstat? freeze plug? heater core? water pump? Any assistance/recommendation appreciated!
