convert o2 millivolts to air/fuel ratio
robztheman
I was just wondering what the math is to convert the o2 millivolts to air/fuel ratio? I am just wondering and would like to know. Also while i am here does anyone know or can point me to a link where i can find out how to convert to a wide band?
thanks
For a NB O2 sensor:
> 450 mV == rich
< 450 mV == lean
For a WB voltage to AFR conversion it depends upon the unit being used. Most are also capable of being programmed for AFR range and the voltage range.
A common AFR/voltage range is 0V for 10:1 and 5V for 20:1
The conversion is then:
AFR = volts * 2 + 10
RemoveBeforeFlight
