Assuming you're using 92-94 octane pump gas: One pound of boost=about 4% HP gain, one point compression= about 2% HP gain. If you up the compression from 8.5 : 1 by one point(which ups the octane requirement), you have to lower the boost by about 2 PSI(to stay out of knock). That nets you a 6% reduction in HP. As posted: boost is worth more than CR(unless you're after mileage instead of speed).
