larrym
West Coast Newfy
- Jul 17, 2007
Buddy of mine is putting together a motor I'm trying to figure out where the piston is going to finish relative to the deck. Experts please point out glaring errors.
JE pistons eagle rods.
So assume you have a block with a 9.510-inch deck height, 5.967-inch connecting rods, and a stroke of 3.400 inches. First, divide the stroke by two and add that to the rod length: 3.400 / 2 = 1.700, and 1.850 + 5.967 = 9.517. Next, subtract that answer from the deck height: 9.510 – 9.517 = +.007. So the answer is that the piston compression height should be .007 inches out the hole?
Based on this what sort of compression with stock combustion chambers
