This is taken from from notes that I took a number of years ago when there was an execellent discussion about the TR ignition.
The output voltage is the primary clamp voltage times the ignition coil turns ratio. So, it is 400 volts X 80 = 32Kv. I wonder if that guy on Jeopardy , Jennings?, would know this piece of trivia
Originally posted by turbopaul This is taken from from notes that I took a number of years ago when there was an execellent discussion about the TR ignition.
For some reason that the link does not work.
Copy link location and paste the link into your browser.
Then remove the period from between the k and the s
