Owlpond1
- Oct 15, 2009
Several years ago I swapped out the original coil with an '87 (with adapter plate). The coil isn't labeled for firing order and I'm not sure what coil it is and can't recall where I purchased it. The poles/posts are offset from one side to the other. Can anyone help with firing order? I wasn't sure it matched the original. Currently one side has wires gong to drivers side and the other side has wires going to pass side but I want to confirm it's correct. Thanks in advance.
