Jackie grabos
- Feb 2, 2011
i have a 87 gn. I bought a new coil module connector from oriely auto. got home and was trying to connect to wiring harness. the connector seems to fit but there is a screw that will not go into coil module. looked and my new coil module has a smooth brass fitting and old one is threaded. is there a certain coil module that has to be purchased to fit correctly? does the ac delco have the threaded fitting? the reason I was changing it is because when coil pack removed top of module looks like laffy taffy. im assuming this heat related and needs to be changed. thanks
