I recently discovered I had been using a NGK type “LHA” sensor with a FAST Classic that have had the universal O2 calibration file upgrade. It seemed to operate the system fine.
In the FAST O2 instruction file for the XFI, it is indicated that " V1.310 adds compatibility with “LHA” sensors, and goes on to indicate selection of the incorrect O2 sensor could result in "erroneous O2 readings".
I am assuming the “L1H1” or “L2H2” sensors are only compatible with the upgraded Classic FAST, or would the "LHA" sensor be accurate as well.
