This is all stuff you can do your self rather easy you may want to give it a shot before you pay some one. To make it easiy on you I would try to get most of it from one place got my parts from Brian at g-body and auto zone here is a good list to start with.
GBodyParts.com Tubular Upper A-Arms with ball joints $170 you can get a simalar set of these about $30 dollers cheaper from speedway I have a set on my car seam to be ok just no customer support if needed.
GBodyParts.com Online
Spohn Precision Front End Rebuild Kit - 1978-1987 GM G-Body with lower ball joints $258
For Braces start with rear seat frame brace and add others later as you go.
Rear Seat Frame Brace Kit $76
Connecting Front Brace $65
Front Frame Braces $50
This last stuff you need but can get it at auto zone
Energy-Suspension / Control Arm Bushing - Front lower $40 Part Number: 3.3171R
AutoZone.com | | Control Arm Bushing - Front | CONTROL ARM BUSHING
Gabriel Ultra / Shock/Strut - Front $ 23 each Part Number: 69600
AutoZone.com | | Shock/Strut - Front | ULTRA SHOCK
Next thing I would do is the jeep steering shaft upgrade have to get ebay or salvage yard for this one. here is a good place to read on it. I got mine for $15 shipt on ebay.
http://www.turbobuick.com/forums/br...270748-steering-shaft-intermediate-shaft.html
And the last thing to think about is brakes I think the best bang for buck upgrade is the blazer brake upgrade only $150 for every thing at the salvage yards here if they have them problem is most dont but you may get lucky. check it out here
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/171079-11-bolt-brakes.html
Now the good thing is if you do every thing on this list and your not happy the only money your out is the shocks so $50 at most and you can probly sell those to some one for $25 so in reality you may loose $25 by doing this first.
Some guys will say the tubler a-arms are not the way to go not adjustable only thing they do is take a puond or 2 of the front of the car dont help improve the suspention any since not adjustable and if you want you can spend $200 or $300 more to get an adjustable set but for what you want I tihnk these will work just fine you dont need to work about suspention drop from drag racing your not looking for a full on road race set up and you will never have to replace that passenger side bushing from the down pipe heat melting it again.
