Hello, I recently got my motor built but noticed the ported heads that were purchased from champion have the casting number 6293.. Has anyone else purchased a set from them expecting ported 8445 and recieved these?? Thanks
They do have the champion name stamped on them just found it odd they would use 6293 instead of 8445. I've read they are the same besides the water jacket but I'm not sure
The 293 heads are the same except for the bridged water passages front and rear that seem to help head gasket leaks in that area. They should perform the same.
Thanks Mike. There was a couple of discrepancies with this build so this got my attention as well. I bought arp head studs from you 123-4003 the builder said they were wrong and had to use the arp bolts instead.. So either the block is different or the heads. But I guess the heads aren't the issue
