Champ Irons w/Bison mods, champ ported intake, champ rails, t&d's + more
kidglok
Balls Deep
All these parts went 9's with a 67 turbo on my 93/alky motor. I went to aluminum heads with a race manifold so the following is for sale. All parts have a dozen or so track passes and maybe 1000 street miles except for the heads which have 3 passes and a few hundred miles since Bison set them up. Paypal +3%, shipped items are to the lower 48.
Champion Irons...modified by Bison with PAC-1203 springs with titanium retainers, locks, viton valve seals. Springs are installed at 1.75-1.76" height with 170lbs on the seat...open pressure should be around 520ish so limited travel or solid lifters are preferred. I was .050-.060 from theoretical coil bind at .587 lift.
SOLD
Champion Ported stock intake- drilled and tapped for vacuum fittings at the back of the manifold, you can always plug these if using the stock vacuum routing. 3/8 npt for the iat sensor, 1/4npt for the brake booster and 1/8' npt for a pushlock fitting. There is also another 1/8" npt tap in the front that i used for my regulator. Includes the EGR blockoff plate.
SOLD
Champion Fuel Rails- for a stock manifold, used on the one above...setup for an external bypass regulator, includes mounting brackets but no fittings.
SOLD
Precision Polished 70mm Plenum- drilled and tapped on the side for 3/8npt where i ran my pcv hose into, or you can use it for iat which is the same thing.
SOLD
1/2" plenum spacer
SOLD
T&D 1.55 Roller Rockers- for iron heads... all hardware included.
$525 shipped
ARP 12pt head studs- for iron heads, all washers and nuts included
SOLD
more pics of the heads
Disregard, just talked to bison, that's to much spring for my combo.
Interested in.the rails. Can you give me till midnight to.see if I can make it work? And ill have a def answer.
yea i shoulve added a disclamer, these arnt for the faint of heart lol
You need either 885 lifters, solids, or a limited travel plunger style lifter with these springs.
Lol right! That's a really great deal but I'm not going that aggressive with my cam. Someone is going to get a badass set of heads for a great price. Glws, Jeff.
