Center caps
Sneezy6
4 never installed center caps. $45 flat, I will pay for the ride. PayPal only, don't worry about the 3%. I just need you to be clear that these ARE NOT factory center caps. I ordered them by mistake and now have no use for them. Believe they were $75 new. Please make sure you know what these are before buying.
I work nights and it may take me a little bit to respond. Please be patient as my schedule is very demanding at work and home. I will respond in order that I receive responses, thanks.
Do you know if these will fit GTA/GNX rims? If so I'm in. Do you have any side pictures of the tabs and how wide is the cap?
Not sure, I can tell you that they will not clear the wheel bearings in stock runs. I will send pictures in a sec.
Hope these help
What's the diameter at the bottom of the tabs?
Yeah they should fit but like you said the issue would be fitting them on the fronts with the bearing caps in the way!
Not sure why they would send me 4 rears, or what these even fit on. Let me know whenever if you change your mind.
