4 CCW classics polished 17x10, 5" backspace. The rub(ill install 1/4 spacer in the front and rear(rub only on a frame on the front at full turn)
Looks good! John @ CCW does know what he's talking about when it comes to these cars...
I have 18 x 9.5" up front and 18 x 10" out back with 4.74" BS (no frame notch) and I have no rubbing issues!
Scot W.
It looks great. I'd call it a success until you hit a serious bump and tear up the sidewalls with the trim (been there, done that). Be careful.
You'll begin to sacrifice a lot if you decide to lower it.
Also learn to resize your pictures.
Your car messed me up so many times. It was one of the reasons I went this route. Where did you run into problems ? Front or rear? fenders or frames?
Hows the size now ?
Size matters on monitors. I use a 30" samsung.
Everywhere.
In the front I've cut out the inner fenders and rolled them, and welded on new steering limiters to the lower control arms to keep the tires off the frame and swaybar. Granted I run the B-body spindles so it changes things a bit compared to stock.
Out back the trim and wheel lips were gone when I bought the car. What was left was rolled tightly back into itself and stretched as much as possible using a fender roller. The frame is factory stock. I think the kids call it "hellaflush", we call it "hellarubber". LOL.
During mock-up:
Hell, even with just 10s and 285s Scot had to rework his car with a fender roller to keep it from rubbing: http://www.turbobuick.com/forums/2437539-post72.html
Fitting 11s (or 11.5, still not sure) and 315s isn't exactly the same challenge. To make an omelet you are going to have to break some eggs... I just happened to use a sledge hammer to do it.
It is fine. It was the "pixelation" that looked like crap... even on my 20-something inch wide screen monitor.
I am going to recommend Nitto NT05 and NT05Rs for tires... stay away from that old 555R crap.
Would you do anything light on the front?
Let me explain a bit more on this, The tires didn't rub AT ALL with the hotchkis lowering springs until there was more than 3 people in the car and even then it only rubbed on the pass side, and the rubbing was so minor it never made a mark on the sidewall of the tire! So just to be safe I rolled the fender lips & Molding by hand with a hammer (Not a fender roller) and I don't really consider it "Reworking my Car" by just rolling the fender lips!! The front was left stock (untouched) and still is to date! New plans are in store for it this year and it's something Never seen on a TB before.Hell, even with just 10s and 285s Scot had to rework his car with a fender roller to keep it from rubbing: http://www.turbobuick.com/forums/2437539-post72.html
Yep!Is it a hover-Buick?
Those look great. I would have thought they stick out more in the front. I had those on my C5, really good wheels and John's a nice guy too.
Very light and strong wheels to top it off.
