Can i take the Catalytic converter off of my 1987 GN.How would it run?
try it you will be amazed
a pound or 2 but nothing to worry about but the spool up will be waaayyyyy faster and it will pull harder. do you have an adjustable wastegate on there or a stock rod? and do you have a scanmasterWill i/I was told the boost with go up a little if i take it off.
I have a stock rod and no i dont have one.i am new to the turbo car.
stock turbo? well opening that cat will make a big difference with that hooker exhaust!!! how does it run nowhi flow fuel pump.disk style injectors.that i know of.Hooker cat back exhaust.
Dont know just got it.what should it run?Yes a stock turbo.where are you from?stock turbo? well opening that cat will make a big difference with that hooker exhaust!!! how does it run now
13's now with good tires and lowwww 12's with good race gas or alky injection. when i first got mine i just put on a ta-49 and alky injection and ran a 11.62 at 114. i am from aliquippa,paDont know just got it.what should it run?Yes a stock turbo.where are you from?
13's as is with 16 psi of boost and low 12's with race gas and 25 psi preferably 112 octane but you need a scanmaster to monitor knock and turn the boost up slow. what chip do you have? you should get a chip from TurboTweak Home it will run sooooo much better. havent seen your site yet. also you should look into WWW.ALKYCONTROL.COM for an alky kit. you can run 25 psi on 93 octane with methanol which is 3.50 a gallon and cools the intake charge and cleans the combustion chambers. race gas is 8.00 a gallon and it ruins the oxygen sensors. alky you can drive everyday on the street with 20 plus boost and eat up those ricers on the street. you will get 100 more horsepowerMy car will run 13's/12's with good race gas.what can i put in it for race gas? Have you seen my site?
Nice i dont have any chip yet,but i was looking into getting one.Nice i will look into that site WWW.ALKYCONTROL.COM I have to go now.i will be back later or in the morning.Thanks for the info.ttyl.13's as is with 16 psi of boost and low 12's with race gas and 25 psi preferably 112 octane but you need a scanmaster to monitor knock and turn the boost up slow. what chip do you have? you should get a chip from TurboTweak Home it will run sooooo much better. havent seen your site yet. also you should look into WWW.ALKYCONTROL.COM for an alky kit. you can run 25 psi on 93 octane with methanol which is 3.50 a gallon and cools the intake charge and cleans the combustion chambers. race gas is 8.00 a gallon and it ruins the oxygen sensors. alky you can drive everyday on the street with 20 plus boost and eat up those ricers on the street. you will get 100 more horsepower
jim
My site is burnoutbox.net i have a forum also.
