Hey y'all
I've finally sort of nailed all of my issues with this car. Except for this last one.
I pulled the catalytic convertor off, because I thought maybe that it was clogged and causing backpressure up in the motor.
Well, it turns out there's no catalyst in the Catalytic convertor. As I began to start the car without the cat attached, the car sounded fine. It revved ok, held it steady pace, it was fine! Loud, but fine! It even started without any hesitation. (In the past, it would take 2-3 cranks before it would start, without the cat on, it starts with just one turn of the key)
So I reinstall the cat to get an idea of what the hell is going on just to make sure. Well, the engine starts shaking side to side due to the catalytic convertor shifting side to side as well. All of a sudden, maybe five minutes into running, the car starts sounding like it wants to shut off. It starts sorta struggling and immediately I turn the vehicle off.
Well, admist all this, I've got a check engine light on. So I'm thinking to myself, what the heck have I gotten myself into? While the vehicle had its catalytic convertor off as well, the check engine light came on. So is the 02 sensor reading funny due to the fact that the cat is off? Or is there a much more deeper issue at hand here?
I'm fairly positive however that the catalyst in my catalytic convertor has went up into my muffler and pipes. As when they were connected prior to taking off the cat, I was having smoke come out of the vehicle. White, puffy smokey smoke. And after taking the cat off, there wasn't any smoke.
Does anybody have any idea's?
-Saladin
-Saladin
