For Personal Use Only Print This Page • Print All Pages
Loading...
Rebuilt/Reconstructed Title
A Rebuilt/Reconstructed vehicle is a salvage vehicle that has been repaired and restored to operation. These vehicles are often severely damaged before they are rebuilt and refurbished parts are typically used during reconstruction. In most states, an inspection of the vehicle is required before the vehicle is allowed to return to the road. Manufacturer Buyback or Lemon
A DMV or a state agency marks an official document or issues a Manufacturer Buyback/Lemon title when a vehicle has been repurchased by the manufacturer. Not all states issue manufacturer buyback titles and the specific requirements for a lemon law vehicle varies by state. Odometer Rollback
If a more recent odometer reading is less than an older reading, then the odometer may have been tampered with and "rolled back". Manufacturer Recall
Automobile manufacturers issue recall notices to inform owners of car defects that have come to the manufacturer's attention. Recalls also suggest improvements that can be made to improve the safety of a particular vehicle. Most manufacturer recalls can be repaired at no cost to you. Basic Warranty
Most manufacturers offer a basic warranty for new vehicles. These warranties vary by manufacturer and typically last for a certain amount of time and/or a set number of miles. Not Actual Mileage Title
When the seller certifies, under the Federal Odometer Act, that the odometer reading does not reflect the vehicle's actual mileage. This may occur because the odometer was tampered with, broken, or replaced. Junk Title
A Junk Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. The majority of states use this title to indicate that a vehicle is not road worthy and cannot be titled again. Some states treat Junk titles the same as Salvage. Loss Due To Fire Title
The vehicle sustained major damage due to fire. In most states, fire damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value. Exceeds Mechanical Limits
A vehicle with a 5-digit odometer cannot accurately track mileage after 99,999 miles because the odometer rolls over. This title is the result of a seller certifying under the Federal Odometer Act, that the odometer reading EXCEEDS MECHANICAL LIMITS of the odometer. Structural / Frame Damage
In most cases, a vehicle is inspected for structural or frame damage, depending on the body design, after an accident or other incident. All levels of accidents from minor to severe can cause structural / frame damage and in most cases it can be repaired. Airbag Deployment
Occurs when the driver, passenger or side airbag has been used or deployed during a crash or other incident. If an airbag has been deployed, it must be replaced by a qualified technician. Have this car inspected by a mechanic prior to purchase. Salvage Title
A Salvage Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. Some states treat Junk titles the same as Salvage but the majority use this title to indicate that a vehicle is not road worthy and cannot be titled again in that state. The following eleven States also use Salvage titles to identify stolen vehicles - AZ, FL, GA, IL, MD, MN, NJ, NM, NY, OK and OR. Total Loss
An insurance or fleet company declares a vehicle a total loss when a claim exceeds ~ 75% of its pre-damage value or if the vehicle is stolen and not recovered. This damage threshold varies by company. These companies typically take possession and obtain the title. Not all total loss vehicles result in a DMV-reported branded title, like a Salvage or Junk title. See the glossary for more information. Accident Indicator
Various events could indicate an accident in a vehicle's history, such as: salvage auction, fire damage, police-reported accident, crash test vehicle, damage disclosure, collision repair facility and automotive recycler records. See the glossary for more information. Hail Damage Title
The vehicle sustained major damage due to hail. In most states, hail damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value. Flood Damage Title
States issue flood titles when a vehicle has been in a flood or has received extensive water damage. Standard Equipment
Power Windows, Power Steering, Air Conditioning, AM / FM CD, Power Brakes, Tilt Wheel, 6-digit Odometer Safety Options
Dual front air bags/active (manual) belts
2003 MITSUBISHI ECLIPSE GTS
4A3AC74H03E014568
HATCHBACK 2 DR
3.0L V6 FI DOHC 24V / FRONT WHEEL DRIVE
Standard Equipment | Safety Options
Hi-I'm the CARFAX Xpert™. I'm here to help you better understand the data in this CARFAX Report. Did you know...
We checked over 5 billion records from thousands of data sources for this vehicle
This vehicle DOES NOT qualify for the CARFAX Buyback Guarantee
The last reported odometer reading was 74,179
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. Other information about this vehicle, including problems, may not have been reported to CARFAX. Use this report as one important tool, along with a vehicle inspection and test drive, to make a better decision about your next used car.
The number of owners is estimated by CARFAX
Year purchased 2004 2005
Type of owner Personal ---
Estimated length of ownership 22 days 2 yrs. 9 mo.
Owned in the following states/provinces California California, Minnesota
Estimated miles driven per year --- ---
Last reported odometer reading 68 74,179
CARFAX guarantees the information in this section
Salvage | Junk | Rebuilt No Problem Alert!
Problem Found
Fire/Flood | Hail Damage | Buyback/Lemon No Problem No Problem
Not Actual Mileage | Exceeds Mechanical Limits
Alert! Severe problems were reported by a state Department of Motor Vehicles (DMV). This vehicle does not qualify for the CARFAX Buyback Guarantee.
Not all accidents or other issues are reported to CARFAX
Total Loss Check
No total loss reported to CARFAX. No Issues Reported
No Issues Reported
Structural / Frame Damage Check
No structural / frame damage reported to CARFAX. No Issues Reported
No Issues Reported
Airbag Deployment Check
No airbag deployment reported to CARFAX. No Issues Reported
No Issues Reported
Odometer Rollback Check
No indication of an odometer rollback. No Issues Indicated
No Issues Indicated
Accident Check
See State DMV-reported Title Problems above. No Issues Reported
Alert!
Problem Found
Manufacturer Recall Check
No recalls still require repair. No Recalls Reported
No Recalls Reported
Basic Warranty Check
Original manufacturer warranty likely voided by manufacturer after vehicle was severely damaged.
Warranty Active
Warranty Voided
Tell us what you know about this vehicle
Still looking? Find similar cars just listed for sale in your area.
Let us do the work! Get daily updates of MITSUBISHI ECLIPSE vehicles for sale in your area.
Email:
Zip:
2002 MITSUBISHI ECLIPSE GS
Body Style: Hatchback 2 DR
Engine Type: 2.4L L4 FI
Standard Equipment: Power Windows, Power Steering, Air Conditioning, AM / FM CD, Power Brakes, Tilt Wheel, 6-digit Odometer
Free CARFAX Report Queens Automall Inc
718-523-9090
Distance: 9.92 mi
View Dealer Inventory
Contact Dealer
Price: $6,675.00
Mileage: 110,050
Color: Silver
Free CARFAX Report Reliable Auto Repairs & Sales
914-736-7517
Distance: 48.37 mi
Contact Dealer
Engine Type: 3.0L V6 FI DOHC 24V
Free CARFAX Report Condemi Motor Company
973-777-2300
Distance: 21.51 mi
Contact Dealer
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. CARFAX checked over 5 billion vehicle history events and found 12 record(s) for this 2003 MITSUBISHI ECLIPSE GTS (4A3AC74H03E014568).
Purchased: 2004
Type: Personal
Where: California
Est. miles/year: ---
Est. length owned: 2/6/04 - 2/28/04
(22 days)
Date: Mileage: Source: Comments:
04/16/2002 Dealer Inventory
Anaheim, CA Vehicle offered for sale
04/20/2002 3 Anaheim Mitsubishi
Anaheim, CA
714-533-2200
www.anaheimmitsubishi.net
ww.anaheimmitsubish
i.net Vehicle serviced
Pre-delivery inspection completed
Wheel locks installed
11/07/2002 Anaheim Mitsubishi
Anaheim, CA
714-533-2200
ww.anaheimmitsubish
02/06/2004 68 California
Motor Vehicle Dept.
Laguna Hills, CA Title issued or updated
First owner reported
Registered as
personal vehicle
Loan or lien reported
02/06/2004 Anaheim Mitsubishi
Anaheim, CA
714-533-2200
ww.anaheimmitsubish
i.net Vehicle sold
02/28/2004 Anaheim Mitsubishi
Anaheim, CA
714-533-2200
ww.anaheimmitsubish
i.net Vehicle sold
Purchased: 2005
Where: California, Minnesota
Est. length owned: 8/4/05 - present
(2 yrs. 9 mo.)
08/04/2005 California
Motor Vehicle Dept.
North Hollywood, CA New owner reported
SALVAGE TITLE/CERTIFICATE ISSUED
11/10/2005 32,110 Minnesota
Motor Vehicle Dept.
Little Falls, MN
Title #J3156T000 SALVAGE TITLE/CERTIFICATE ISSUED
11/06/2006 Minnesota
Motor Vehicle Dept.
Little Falls, MN
Title #J3100U480 SALVAGE TITLE/CERTIFICATE ISSUED
If you are buying this vehicle from a private seller, check to be sure any associated lien on the vehicle has been paid off.
02/02/2007 74,179 McKay Family Dodge
Saint Cloud, MN
320-252-7170
McKay's Family Auto Chrysler Jeep Dodge and Mitsubishi Vehicle serviced
Oil and filter changed chassis lubricated
09/06/2007 Minnesota
Motor Vehicle Dept.
Little Falls, MN
05/09/2008 Mitsubishi Motors No recalls open for repair
Have Questions? Please visit our Help Center at
CARFAX used car VIN number search, auto history check, vehicle history reports
