turboculosis
Pleasant peasant
- Jan 19, 2002
Just got the turbo back after getting freshened up at Limit Eng.As I took her for a ride with the fresh turbo in, she started smoking again but not as bad as with the bad seals.It only tends to smoke when temps are around 180*coming off a stop,then goes away.I don't get any smoke under WOT,but once I let off I get a small puff.It's definitely oil burning (bluish in color).I removed the turbo outlet hose to see if it was the turbo,no oil(dry).I removed the plugs and found oil not so much on the electrode but mostly on the threads of the plug.I am leaning toward the valve guides and or seals,and pulling the heads to verify the problem.Now,is this the way to go?Or am I going about it the wrong way?Is it obvious I have bad piston rings???Thanx for you time,Alan
