I just changed my fuel filter to an AC Delco fuel filter, I made sure that it was installed properly as well. Now my car has an off idle stumble, a check engine light on. What gives? A defective fuel filter? AC delco? I don't have a scanmaster so that sucks. I drive the car, and under light throttle it runs fine, but slightly depressing the gas pedal results in the car hesitating and holding back the boost. The vehicle has a hot wired high prssure fuel pump, 36 lbs injectors, new injector harness, but it was all running fine before I changed the fuel filter. What would likely be the cause?
