Charles Young
C Young
- Sep 25, 2012
Ever since I made a few passes at the TB.com nationals the car has been smoking some. I can see it at idle, especially when I rev it up a little but cannot really tell if it smokes at cruising speed. I'm sorry but I cannot tell what color the smoke is. I'm thinking I hurt something so I looked at the turbo to see if I could see oil blowing by seals but all looked normal. Did a compression check and all cylinders were between 120 and 130 psi; no obvious problem there, right?
Decided to go for a little drive and noticed O2's weren't changing much then saw O2 cross counts stopped at 147; not changing. Aha, so I'm thinking bad O2 sensor. I have narrow band factory style. That could cause some smoking issue I think. Bought a new Denso sensor and installed it. Fired it up. CC's jumping around like it used to, don't see any smoke.... yeah! Then CC's stopped again. Still seeing a bit of smoke.
Questions:
Charles
Questions:
- Could a bad O2 sensor cause the smoking issue I described?
- After warm up, aren't O2 cross count numbers supposed to constantly change pretty quickly when the car is idling?
- What are the odds of both old and new sensors being bad?
Charles
