G gsbuick65 Member Joined Jun 7, 2001 Oct 29, 2011 #1 when I put it in park the car takes to long to idle down, about 8 seconds, have 87 ecm with 87 chip and 87 maf sensor. tomco green strip injectors, friend was thinking maybe I need a chip made for my setup. what yall think?
W WH1_T-Type Well-Known Member Joined Jun 1, 2009 Oct 29, 2011 #2 Do you have a scan master? if so, what does your IAC read? What chip is currently in there? Stock? What is 'high' and what is 'normal'?
G gsbuick65 Member Joined Jun 7, 2001 Oct 29, 2011 #3 WH1_T-Type said: Do you have a scan master? if so, what does your IAC read? What chip is currently in there? Stock? What is 'high' and what is 'normal'? Click to expand... Stock 87 chip, not sure how high, just fast then comes down, iac is 17
